Re: How to:ECU Reset,Throttle & Accelerator Position Learning
Originally Posted by mpchrist1
I just purchased a used 2004 Titan and the SES light keeps coming on and I keep going back to the dealer to get it turned off. They claim nothing wrong with the truck and I must have loose gas cap. I have checked this and made sure it was tight the last time I filled it up but the light still comes on after a couple of days. Will this method work for getting the light to go out and will it alter anything else on the performance of the vehicle? I have not made any changes to the vehicle so add ons are not an issue. Will this hurt the truck in anyway? Doesn't pressing and releasing the gas pedal automatically flood the engine?
Thanks in advance for your help
It will turn off the light but if the problem is still there the light will come back on.
Swing by your local autoparts place, most will read the code for you free of charge, with the code you will know exactly why it's coming on.
Don't reset your ECU unless you have to, you will see your MPG drop like Enron's stock.
Titan/Armada Part Numbers
305.5 WHP, 370.4 ft/lbs tq
