Are you sure you have VDC?
If the "VDC" light isn't in your instrument cluster, you don't have VDC.
If the dealership runs your VIN, they can tell if VDC is really there.
Otherwise, the switch plugs into nothing.
I went through this to discover I only had ABLS, which in my opinion turns out to be a good and bad thing.
To my knowledge, ABLS can't be turned off at all.
I hope that this helps to ease your mind because it is frustrating not having control of things like VDC, ABLS and improving MPG...smiling.
