Old 03-26-2008, 05:50 AM   #8 (permalink)
loufish
loufish's Avatar
Re: How can i shut off my VDC?
well everytime the tires start to spin the engine basically shuts down and the light flashes in the cluster, like it used to do with my 05 x terra, but the x terra has the vdc button
The Titans have ABLS which tries to keep one wheel from spinning faster then the other, when it senses one wheel slipping it flashes "SLIP" on the dash and applies the brakes to the spinning wheel.
If you have the brakes already on like trying to do a brakestand, the truck will cut back power...
PRG Performance Kit w/SAW's
Born 9/2004
2002 Honda XR650R
