Old 03-26-2008, 09:14 AM   #10 (permalink)
JLG_Engineer
JLG_Engineer's Avatar
Re: 2008 Titan Defect?
[quote=54warrior]You'll hear a loud bang or clunk when going over a speed bump or something similar. First, the suspension will compress when you initially hit the bump. Next, as you go across the bump and the suspension begins to rebound, combined with the truck now being 'across' the bump, the suspension is forced downward to it's limits, which just so happens to be limited by the shock itself. The shock 'tops' out and prevents the suspension from drooping any further. The clucking sound is the shock topping out/destroying itself.[quote=54warrior]
Exact same issue I have
JLG_Engineer is offline   Reply With Quote
