Originally Posted by NYTITANMAN
Nite, How easy is it to remove? How much does it weigh?
Flfinfan is right, just 4 C clamps. Don't know the weight for sure, guess less than 100#. It would take two people due to the width not the weight.
I'll let you know later if this works, I plan to use a hoist and a spreader bar so that I pick it up at the 4 corners. I will then fix it where one person can take the clips off and then just hoist it up into the ceiling of the garage. Then just drive out from under it. Reverse for re-install! This is nothing new, they do it with vehicle hardtops.
NITEBLITZ
