Originally Posted by gabe
sup dudes, got an 04 kc 4x4. did a rc leveling with a 2" block in the rear. mud grapplers 33x12.50 on 17x9 black xd revolvers. it's a daily driver, with some mudding, but mostly highway. well i dream to go big (like 12" big), but it will be over a matter of time. so what can i aim for component wise, names, brands, models etc. what can i combine to achieve such a lift, but as well i don't want a crappy drive afterwards. i'm new around here so any input would be nice, thanks dudes.....
if you want it to ride good, stay away from bulletproof.
if you are on a budget but still want some nice parts contact Greg at PRG and he can hook you up with a 10" kit.
It consists of the 6" Fabtech Stage I lift with Radflo 2.5 coilovers. You crank up the coilovers and then install a 2" coilover spacer on top of the coilover. To do this you will also need PRG Upper Control Arms. In the rear you will need Deaver 2.5 leaf springs. You will also need a 4" tapered block. And then you will need to have aftermarket shocks as well.
When all is said and done you should have 10" of lift in the front and 7" out back. If that isn't enough you can add a 3" Performance Accessories Body Lift.
With a 10" lift you will be able to run 37s with only doing the pinch weld mod. With 13" of lift you will be able to run up to a 38.5" tire.
Good luck and I hope you got deep pockets.
2008 PRO-4X w/ leather, RF, BT, CC, Shortbed
MODS: McCulloch 6000K HID kit: Low Beams, Apexcone 6000K HID kit: Fogs, 20% front tint, 5% rear tint, 2 10" Boston Acoustics G1s, Alpine PDX-1.600 amp
Originally Posted by BKW
The problem with the 5.3 Chevys is: Their get up and go...got up and went.
