Old 04-01-2008, 06:20 PM   #7 (permalink)
TitanTech659
TitanTech659's Avatar
Re: Coolant replacement??
Originally Posted by Justintoxicated
I thoguht it was just every 30k and I thought you needed a flush machine to do it. Otherwise your only doing a partial change? I did mine at 40k I'm not sure how much difference this really makes.
You dont NEED a machine to flush the coolant. Just take the radiator cap off and pull the drain plug. Then take off one of the heater hoses and run a garden hose into it. That will flush out the heater core and the block. You should see the color change from green to clear when it comes out of the drain plug. To fill the system clamp off the overflow hose and fill the radiator. Put the radiator cap on then fill up the tank. Let it run for a while (keeping it filled) untill the heater is consistantly hot. If the heater is cold at idle then you didnt get all the air out.
TitanTech659 is offline   Reply With Quote
