Old 03-23-2004, 10:05 AM   #2 (permalink)
titanjbc
titanjbc's Avatar
It will partly depend on the trailer you are towing. Is it an RV, or something else? You want the trailer to be level when towing, so it's best to level the trailer and measure the distance from the ground to the top of the hitch. Then measure from the ground to the receiver. The difference is the approximate drop. If you are going to use a WD hitch, this gets a little more complicated.....
Titan SE CC 2WD
Smoke / Graphite
Pop. Pkg. w/Capt., Big Tow, Util. Bed Pckg.,
Splash, Mats, Fog Light Kit, Step Rails
Leer 100R Cap
Hornet Lite 24RS Travel Trailer
Reese Straight-Line Hitch (WD System with
Dual Cam Sway Control) Prodigy Brake Controller
titanjbc is offline   Reply With Quote
