I needed a 4" drop, but you should measure. Use the trailer tongue stand or other jack to put the tongue in the right position, then measure from lower level to ground. Subtract this number from the height of your receiver to the ground and that will be the amount of drop you need.
2004 Titan SE Crew Sportfishing Edition
Deepwater blue with Big Tow, Active Braking Limited Slip, Utility Bed, Bench Seat, Foglights, Tech Tube Steprails, A.R.E. LSII bed cover with keyless lock, Save the Reefs tag, Fishing CDs in the player, and Fishing Themed Graphics
Born: 12/15/03
