Old 04-08-2008, 12:17 PM   #21 (permalink)
DanBlp
DanBlp's Avatar
Re: Nismo Cat back Install
Papa, I assume you have already put in an x-pipe; if so, how far in front of the mufflers do you reccomend; or did you put it right after they straighten?
As far as the 0-60, conditions are always different and I did not run my old system and nismo on the same day; both in the cool am air though. Did you expect my 0-60 to go up or down. Honestly, my truck does not run much different. Thanks for the advice on the x-pipe.
Originally Posted by Papa_D
I'm actually surprised your 0-60 remained the same but that's good news for those concerned with the low end.
If you want to pick up a little more mid and top end, install a Dr Gas Xpipe where the exhaust straightens out, it will also smooth out the exhaust note and should decrease the in cab noise level somewhat.
2006 Titan SE CC with Big Tow
Uprev, Nismo CB, Volant CAI, PRG mini-leafs on rear, 4x4 coils up front, Bilsteins F&R, Hellwig sway bar rear, Nismo 20x9s w/ Sumitomo 305/50 HTRs, Myron & Davis DVD, Nuvi 650 mounted and hard-wired, Bel RX-75 Pro Plus remote radar detector and laser jammer, Armada air damn, Stillin grounding kit
Up Next--Big Brake Kit and Bak tri-fold bed cover
Best 0-60 is 6.31s
DanBlp is offline   Reply With Quote
