Old 04-08-2008, 12:07 PM   #9
desertruner09
desertruner09's Avatar
Re: Transmission temp red-line??
Originally Posted by loufish
At 5000 lbs, it takes a pretty flat road with no headwind to keep it in 5th(OD)
I'd be towing in 4th gear all the time...AND downshifting to 3rd on hill before the trans thinks it should.
I agree, don't let the transmission do the shifting while towing at highway speeds. I tow a 3500 lb TT and I tow in D, but I am make sure that the torque converter locks. If it doesn't lock, I pull it down to 4th. Also don't be afraid to grab 3rd and use all the torque that these engines put out in the 3600 to 4000 rpm range, which also helps to cool the trans. fluid. I've had the engine at 3700 rpm up a hill for 15 minutes in 100+ degree weather, zero problems.
desertruner09 is offline   Reply With Quote
