Old 04-08-2008, 06:10 PM   #2
pedalhappy1053
pedalhappy1053's Avatar
Re: Transmission slipping
Originally Posted by gumby
2004 2wd with the offroad towing package. I know offroad package and only 2wd but yes it is. has 73,000 on it I bought it at 52k a year ago. Dealer did the transmission flush at 58K I noticed at 65K that the tranny was slipping once and awhile when starting out on a cold morning not everytime but enough to notice it. then it only happens in first gear. now however I am noticing it more and more. It does not happen when I use the manual shift mode even when cold nor when it is warm or in a higher gear only when using the automatic shift function. whats the fix? or is it on the way out?
Ok, I know its bad when a transmission slips but what is it? What are the symptoms of a "slipping transmission?"
NEXT MOD: UPREV And Trutrac
MODS DONE: K&N FIPK Intake, Throttle Body Spacer, BANKS exhaust, 6" Pro Comp Lift, SAW Coilovers with PRG Upper Control Arms
pedalhappy1053 is offline   Reply With Quote
