Old 03-24-2004, 08:56 AM   #3 (permalink)
Austin
Austin's Avatar
Originally Posted by Takideezy
Appreciate any suggestions. Takideezy
Wandering can be caused by front toe out - for better highway stability, increase the amount of front toe in.
The oem alignment specs call for 2.8mm (+/-1mm) front toe in. Get an alignment, and make sure that you have at least 2.8mm front toe in. If you already have that much, set it to 3.8mm or even more front toe in.
