Titan Pro-4X towing capacity
I have a 2008 Titan Pro-4X without the towing package. I opted not to spend the $$ for the towing package because my truck already has the lower geared rear end, class lV hitch w/seven pin plug, electric trailer brake pre-wiring, heavy duty 710 CCA battery. The only things the actual tow package would add is the extendable towing mirrors (which I don't care for anyway), and the transmission temperature gauge that I don't really need. My question is this: Would my towing capacity be the same as if I had the actual towing package since I already have the most important towing "stuff", or is there something magical with the trans. temp gauge and the towing mirrors that take the towing capacity from 7300 to 9400 lbs? I am assuming that my truck has the higher towing capacity. Am I on track with my thinking? Thanks!!
