Old 04-10-2008, 07:58 AM   #4 (permalink)
JohnS
JohnS's Avatar
Re: Titan Pro-4X towing capacity
Originally Posted by dustlane
I have a 2008 Titan Pro-4X without the towing package. I opted not to spend the $$ for the towing package because my truck already has the lower geared rear end, class lV hitch w/seven pin plug, electric trailer brake pre-wiring, heavy duty 710 CCA battery. The only things the actual tow package would add is the extendable towing mirrors (which I don't care for anyway), and the transmission temperature gauge that I don't really need. My question is this: Would my towing capacity be the same as if I had the actual towing package since I already have the most important towing "stuff", or is there something magical with the trans. temp gauge and the towing mirrors that take the towing capacity from 7300 to 9400 lbs? I am assuming that my truck has the higher towing capacity. Am I on track with my thinking? Thanks!!
I went to the nissan site and went to specs and options > capacities then under the column for pro-4x it looks like this
King Cab
Standard Bed
Maximum towing capacity (lbs.)
Without Tow Package
4x2 N/A
4x4 7,300
With Tow Package
4x2 N/A
4x4 9,300
Crew cab
Standard Bed
Without Tow Package
4x2 N/A
4x4 7,300
With Tow Package
4x2 N/A
4x4 9,300
not sure what the difference is, maybe the amount of leafs in the spring pack?
John
JohnS is online now   Reply With Quote
