04-10-2008, 07:36 PM
#10
Re: Transmission slipping
Is the fluid burnt? If it is doing what i think it may keep slipping so that it does it in each gear. Is it only under acceleration? This is when most of the load and slipping occurs and even at very light pedal. You probably will NOT get a check engine light. Go to the dealer and see what pulls up. Maby a CAN communication line code. Hopfully it is nothing, but go get it checked ASAP! Good luck
