Originally Posted by HudsonValleyTitan
The Ranchos are quite different...maybe not better than some others.....definitely better than the crappy regular stockers and there are probably better shocks out there but these handle a large tow and go OR very very well. If it ain't broke, don't fix it. I often disagree with reviews. How a vehicle is used makes a big difference. I'm not jumping berms or dunes and had no issues with the Ranchos on my 04. And I don't usually keep a vehicle long enough to need shocks replaced...  .
If by quite different you mean painted white with stickers on them then you are correct. They base line Ranchos. Put on for name only. They are not an expensive shock. They are generics that are sold under many names. Edelbrock, Skyjacker and many more. They are one of the reasons I didn't bite for the "Off Road" package. When I did the math it was essentially skid plates, overrated shocks, a electric locking rear diff, different tires and wheels and the low ratio rear gears. The only significant change from a Titan with Big tow was the e locker which was no big loss as it only came into play if using 4wd low.
