You can get a wiring harness for driving lights with a relay very cheap, maybe $10 - 15 or something like that. I think even Wal-mart has them.
You have an available switch blank at the lower left of the driver's lower dash panel. You can fish wires for the switch through the hood release cable grommet in the firewall using a coat hanger. You can easily wire the power wire directly to the screw terminal on the battery and use an in-line fuse holder.
Now you think you have lemons, but you can make lemonade, as you will have these advantages over the "ordinary" Titans with fog lights:
1. You can run them without the headlights on as daytime running lights.
2. You can run them with the brights on (factory fog lights turn off when you put the high beams on).
Cheer up!
