Originally Posted by Likecars
I asked and the service rep said the tech did balance them. I did not make him go ask if they in fact did not require new weights.
I do have a slight wheel vibration at 48-52, that's why I went for a balance. It's the first balance since I bought it, been doing my own rotation every 5K or so.
Thanks for weighing in.
Nice pun.
If the wheels did not need to be rebalanced, the weights more than likely will not be changed. Most wheel weights are made out of lead and that stuff is a bit on the pricey side these days.
If you still get a vibration between 48-52 MPH request that the tires be "bulls eye balanced". Standard wheel balancing just rounds the weight to the nearest once. Bulls eye will give you a perfect balance. Most newer Hunter™ machines are configured to do so.
