Originally Posted by Nismoaddict
I am looking at a 2008 Titan SE CC Long Bed, Love the truck, but I have to do the research first. You know the stuff that you can use to justify things to yourself and the wife. My lease is ending on my F150.
I am looking for anyone who has experience with the F150 or Titan to chime in on this one.
I currently have a 2006 F150,4WD 5.4, Edge programer and supersprings load assist springs. I tow a Laredo 29rl fifth wheel weighing in at 8000# dry including a tounge weight of about 1500#. I do not carry cargo in the truck other than my wife and 4 yr old daughter. The 150 with the programmer and helper springs tows this combo beautifully, I live in MI and have taken it to Maine and down to TN with no problems except an Temp Warning on the hills of the Penn. Turnpike.
Both the Titan and F150 have almost identical towing and payload specs, and I know I am nearing if not slightly surpassing them. I understand the concepts of UVW and GVWR, etc.
My question is this, Since the vehicles have almost identical specs with the Nissan winning on HP & Tourqe, Can I expect the Nissan to pull as well as the F150 if I add springs? And will the Nissan actually carry the same payload since the specs are within 40lbs of the Ford? Also, I am concerned that the Rear axle and Tranny may not be as "heavy duty" as the 150.
Thanks for any experience you can provide, I have to make a decision within two weeks. Oh yea, I should mention I can get a fully loaded Nissan SE for less than my "A" plan 150. Sad but true. Please no bashing.
No bashing! I like the Ford and it sounds like you have a good one. (I'm from Grand Rapids/Traverse City, myself!)
The redesign of the rear differential occurred with the 07-08 models as well as bigger brakes and rotors.
Transmissions have not gone out on the Titan.
If you need to add springs, you can expect to pull what you pulled with your F150. If you were comparing to an F250, I would say keep your current vehicle.
Let us know what you get!
