i have a 07 CC XE. the dealer tried to program a FOB but couldn't get it to work. I read somewhere on here that there is a way to change the programming options with consult II. have yet to get it back to the dealer to try this
i can't post links yet, but search user "cpaul" and "07 XE Keyless Entry" as the title
Ok, I figured this would happen so I went out yesterday evening and programed a 07 cc XE w/power windows and locks just to make sure I wasn't crazy. To perform this procedure hook up Consult and select Nissan and give it a few minutes to load. In the menu you will have selections like engine, trans.,abs,bcm,airbag,hvac, and so on. not in that order. Select bcm. then select bcm again. Scan down the list till you see configuration and select. You have two options. one is read configuration and the other is write configuration. Select write configuration and when the screen pops up to only do this when replacing bcm select ok or yes don't remember which it says. When you see the next screen it will say manual setting item over two columns. First column will say over the top of it Item. The second will say Set Val. Under the column that says Item there will be one that says Keyless Entry, across from it under the Set Val column is the current setting. If it says With then your truck is already set up for it, if it says Without then tap the screen over the word Without and it will change to with. Then press change and it will start to print the list of manual setting items and the list of auto setting items. I will also have the part # of your bcm which should be 284B2-ZJ20A. Then press OK. Since you are already in the bcm area go to the part to program the remotes and program them. I have the Consult printout where I did this in my hand but for some reason my scanner does not want to scan them or any thing else for that matter. Oh the part where it says auto setting items the dealer cannot touch. I know it would be tempting to try to change some of these other items because I have read a bunch of other threads about some of them but the dealer can't.
