Old 04-17-2008, 07:27 PM   #11 (permalink)
KILLswitch
KILLswitch's Avatar
Re: Installation of SAW's, Traction Bars, UCA's and Cambolts
great write up just one question tho, when installing the spring hat you said
"Take the allenhead bolt that came installed in the SAW’s and throw it away… or into your “spare parts tray”. Using
the new, shorter length allenhead bolt that PRG provides, put the new shock up through the shock hat and fasten
the allenhead bolt through the top of the shock. Note: the Schrader valve should be facing OUT after installation."
why cant i use the bolt that originally came with the coil overs?
KILLswitch is offline   Reply With Quote
