Re: Installation of SAW's, Traction Bars, UCA's and Cambolts
It is too long and will bottom out before it is tight. Greg supplies a slightly shorter one when he ships out the Titan spec'd SAWs, so use that one instead of the longer one. Otherwise, you will have a "clunk" on the front end you won't be able to explain or figure out, because as far as you'll know, everything will be tight.
AKA: Cheap Whore™- IT'S ALL MY FAULT!
Pit Crew Chief
