Old 04-20-2008, 12:24 AM   #25 (permalink)
jkat
Re: Front Axle Failer Thread
I put dr coilovers on my front, which gave me a 1-2" lift. One year went by then my front axle started leaking, Nissan refused to warrenty or even FIX for a fee!!! I had to take it to another shop have them look up the parts, go back to Nissan order the parts, wait a week pick them up and take them to another shop to be put in. My c clip popped out, which cause the front axle to pop out as well. I was so pissed at Nissan, I started reading all the problems others have with the Titan, I traded my Titan in. I did not want to get stuck with a money pit lemon. I learned much from this experience, if you decide to lift your Titan or put larger tires on your Titan, you WILL have problems with your front axle and you will not be covered under Nissan's warrenty. I wish I would have known this before I lifted my Titan. I do feel that the Titans suspension is sad at best, but I had no recourse because of the lift. Please don't believe in the Mag Moss law it is not intended for modifications only things like oil filters and so on. It is also easy to show how a lift and larger tires will change to stress on the front suspension.
If you are thinking of lifting your Titan, my only advice is DON'T!!!!
jkat is offline   Reply With Quote
