Old 03-28-2004, 07:48 PM   #4 (permalink)
1BadTitan
1BadTitan's Avatar
Originally Posted by bighawaii
id recheck all parts again and also see if anythings rubbing or in a bind. your springs are seated correctly right? were there any notchs or markings on the strut mounting block or upper plate? someone with a manual could tell you for sure, im sure sumone here has it or you could dl it for around 20$.
There is a punced hole about 1/4" round on the top of the spring plate and also one on the front of the upper control arm, I lined those up like I thought it should be, nothing is bound up and everything feel fine and looks good, just that damn rattle. Yea the springs are seated right, I worked on imports for a little over 7 years and the strut assy's are pretty much the same, but I cant figure out why this is doing it. And yes, I installed it myself, took about 3 hours, my impact gun took a s#it and I had to stop and go get a new one. So probably like 2 hours.
1BadTitan
BASICS: Black LE KingCab 4x4-Off Road Pkg-Utility Track Bed-Big Tow Pkg
EXTERIOR: 10,000K HID Headlight Conversion-AVS Bugflector II-Wade In Channel Rain Gaurds-Smoke Headlight Reflectors-Shaved Emblems-Painted Red Calipers-Smoke Taillights-Stainless Nerf Bars-Shorty Billet Antenna-20% Tint-5" Exhaust Tip-DIY Custom 3rd Brake Light-Tailgate Assist-Custom Home Made Hitch Cover
INTERIOR: Shortened Shifter-Nismo Pedals-Dynamat Everywhere-Factory Cointray-Carbon Fiber Accents
ROLLERS: Stock OR 17's With Nitto Terra Grapplers 295/70/17
ENGINE & PERFORMANCE: PRG Lift Kit-Nismo Billet Oil Cap-Platinum Terminals-Fram AirHog Filter-Slotted Cross Drilled Rotors
I.C.E.: Eclipse AVN2454-JL Audio TR650 6 1/2 Coaxials-JL Audio TR650 6 1/2 Components-Hardwired Radar Detecter-Add On Remote Start-MICRO Alarm
Other Rides: 05 Suzuki GSXR-03 Suzuki Quadracer LTZ-400
