Old 04-21-2008, 01:12 AM   #10 (permalink)
Titan-ization
Titan-ization's Avatar
Post Re: tranny failure !!................................
Originally Posted by titaninak
ok, here is what the service advisor told me, they found a lot of aluminum shavings in the tranny, now that tells me nothing, he did not have an answer he would give me, i don't think their top tech knows, they are replacing tranny, (trans cooler and radiator, now that tells me they could possibly be the cause,) can someone with input explain how that could happen. I am at loss on this one.
Ok, here we go.....try to make this short and sweet.. The transmission (trans) cooler is fed from the radiator. The radiator acts as a heat exchanger, if you will for the transmission via the trans lines). The radiator is basically cooling your engine and transmission, but each has their own thermostat to control the amount of "cooled" fluid ti wants to flow through the lines. If you have a clogged line, bad thermostat, etc. etc. you are going to have cooling problems with the transmission. The gear tolerances for spacing and throw out bearings, etc. are pretty tight, if they start to overheat due to lack of temp control from the trans cooling lines, the internal parts (gears, etc.) will expand, this will cause metal on metal contact due to the expansion from the heat, creating the metal 'shavings". Over time this will also round out the gears, causing the slipping of the trans trying to shift from one gear to another and "engage" into another gear. This can also lead to "hunting" for gears, if it does not lock into the proper gear during shifting.
So, there must be something wrong with the lines from the radiator to the trans cooler and that is why all three are being replaced.
**on a side note: expansion and contraction of the gears from heat is normal, within a specified temperature range. The spacing of the gears are set up to accomodate the expansion effect from heat, but within a specific heating tolerance coefficient. i.e. from 0-240*F with normal operating range being between 110-180*F, as an example...this is a random figure to illustrate my point, not necessarilly the actual figures for the Titan trans temps.**
Hope this helps a little.
2005 Nissan Titan KC SE 4X2 Tow package, popular package, drop in bedliner, running boards, 2* advance, 18" wheels, Rear sonar, adjustable pedals, 6-disc in dash CD, full frontal brush guard, heated mirrors, head mounted driver info center, auto adjust rear view mirror, home link system, Flowmaster Super 44 hidden dual exhaust, Cobra LTD 29 40 channel CB with dual antennas, tool box w/ black diamond plate
Titan-ization is offline   Reply With Quote
