Re: Front Axle Failer Thread
Originally Posted by jkat
I put dr coilovers on my front, which gave me a 1-2" lift. One year went by then my front axle started leaking, Nissan refused to warrenty or even FIX for a fee!!! I had to take it to another shop have them look up the parts, go back to Nissan order the parts, wait a week pick them up and take them to another shop to be put in. My c clip popped out, which cause the front axle to pop out as well. I was so pissed at Nissan, I started reading all the problems others have with the Titan, I traded my Titan in. I did not want to get stuck with a money pit lemon. I learned much from this experience, if you decide to lift your Titan or put larger tires on your Titan, you WILL have problems with your front axle and you will not be covered under Nissan's warrenty. I wish I would have known this before I lifted my Titan. I do feel that the Titans suspension is sad at best, but I had no recourse because of the lift. Please don't believe in the Mag Moss law it is not intended for modifications only things like oil filters and so on. It is also easy to show how a lift and larger tires will change to stress on the front suspension.
If you are thinking of lifting your Titan, my only advice is DON'T!!!!
nice first post...
sorry that you had problems with your titan and end result traded it in...
Not every Titan out there is a bad seed, and not every dealer is bad either. Sounds like your dealer was full of pricks and you should have called Nissan.
I hope whatever vehicle you replaced it with is trouble free for you. But one bad dealer and a popped clip is not reason enough (for me at least) to feel that you are in for a world of maintenance nightmares.
05 LE Crew Cab Smoke OR 4x4
airbox mod with K&N
ScanGaugeII/blendmount
Roadmaster Active Suspension
NCD leveling kit installed 3/10/09 Thanks Adam!!
MVP Titan sticker on 3rd brake light.
2º Timing advance, Thanks John! 11/14/09
new wipers installed 2/23/10
future mods - JBA Evol  , Injen Powerflow, and more
