Re: Titan's first trip to the dragstrip
I hooked them up to a switch I have the wire from the ecu coming in to the supply and the wire to the sensor coming into the load of the switch. I also ran a ground wire and the switch would light up when I flipped it on. It seemed to work well on normal roads but maybe its just one wheel spinning and the other not. I thought that 4x4 already had a locker so they should both grab.
Curtis
