Got it to work. Thanks all.
Well, I did finally get my Genie opener programmed. Yes, following the manual step by step did the trick. The order is key.
1. First, must program one of the Homelink buttons using one of your rolling code Genie controllers.
2. Second, you must hit the learn button on the Genie main unit in your garage, then within 30 seconds or so, press the Homelink button that you used in step one.
Thats it.
