Old 04-21-2008, 03:14 PM   #2 (permalink)
hooligan
hooligan's Avatar
Re: Tips for towing in the sand
Originally Posted by doberboy
I'm thinking about taking the family to Pismo Beach this weekend and was wondering how the Titan would do in the sand pulling a 23' toy hauler. I have a 4x4 with BFG ATs. I'm a little nervous because I drove onto a small patch of sand in Glamis and barely got out. Reading a few posts, it seems like I should lower the tire pressure to about 15lbs. Any tips or suggestions are appreciated.
don't know about towing but definitely air down to the teens, 15lbs is good. keep it in 4x4, don't ever peg the throttle when at a dead stop. rapid acceleration will only bury you.
for piece of mind i recommend buying a set of these especially since you'll be towing. http://www.terra-trax.com/pb/wp_b9d3...22355354241663
if you weren't towing i'd say you could do without. momentum is key, maintain momentum at all times. at pismo especially always turn from high to low, never low to high. pismo has spots of extremely deep sand, but for the most part you should be able to make it all the way down the coast in either direction on the hard pack portion of the sand.
PRGsite <> PRG/ID prerunner fenders
