Old 04-21-2008, 05:45 PM   #7 (permalink)
gyrate
Re: QX56 Instrument Panel in Titan???
i have that in mine. worth it.. i always hated the stock titan cluster. looks like something the military discarded.
it goes like this:
2004-2006? qx will fit
2004-2007 titans.
2008 are different for both models. not sure if they can be swapped between 2008s though of the 2 vehicle.
for the older years when putting it in the titan theres few things to consider
1. the 2006 Titan has an extra plug in the back. the qx cluster (2004-2005?) has no place for that so you dont plug it anywhere.
2. because of that i presume your cruise control indicators will not work. you will get the cruise light to turn on and stay on but nothing else will show. cruise will still work but you will get no dash confirmation of that.
3. VDC OFF warning light will be on. not sure if thats limited to certain titan models only
4. its a digital backlit led cluster, so some leds might flicker and fail at random. one of my voltage bars currently does that. this was a terrible issue with lexus and audi in the 90s and i see infiniti is not immune
5. the oil pressure gauge seems to be a little off. will measure ok at idle but will go all the way up at 1800rpm. not sure if it is supposed to do that.
6. transmission gauge will function! even if your titan does not have the BT package. yay?
My TT status expired! Wow it's been a year already? Time flies!
gyrate is offline   Reply With Quote
