Re: TRUETRAC Mag-Hytech Diff Cover AND 3:73 GEARS
305/35/24 on wifes. So, if you have a 4x4 could you not change the gears just in the rear and run it 4x2? So no 4x4 has ever done rear gears? If the diff is the same as th 4x2 it should be possible. Would it then be possible to get BT gears and just live with those for awhile? It is possible Superior is just putting feelers out to see if it is really feasable to move forward with gear... I really want 37" but want to get the gearing right. Maybe I should be going custom and changing the diffs? Is this even in the real of possibility like I have done on hot rod before?
