Old 04-22-2008, 10:19 PM   #14
titaninak
titaninak's Avatar
Re: Transmission slipping
uh hum, i hope its something easy to fix, I really hate to see this happen to the titan, i had a slipping problem, at first it seemed to just slightly slip at higher rpms, a real quick abrupted jolt, than over time it would start slipping and sometimes vibrate the whole truck. I hope its not that for you as it sounds your out of warranty. my trucks in the shop awaiting a new tranny and trans cooler and radiator because they found metal shavings in the tranny, I have 28,000 mi. maybe you can drain the tranny and investigate to see if your fluid is burnt, metal shavings etc....... good luck on getting that resolved.
2006 LE, CC, BT, 4x4-Blizzard White
JBA catback, K&N cai, poweraid TBS, grounding kit, 2 degree timing, UpRev tuned <in progress, TruTrac
Debadged,4 piece billet grille, Diamond plate truck Box, 20"Akuza wheels, tech12's w/ Memphis PR1-1000 amp / M-10's, Kenwood 7019 DD,DVD HU, Line of Fire LED light bar, LED third brake light, ADJURE crystal eyes tails, EFX HID lows and fogs, painted to match MADA air dam / inchannel window visors, Stillen Billet aluminum cap covers, 15% front tint, Non BT mirror swap.
titaninak is offline   Reply With Quote
