Re: Titan XE Stereo Swap
This is not a simple swap! The bezel is different when moving up from the 'simple' radio. There is a short cable that goes from the bezel to a harness connector. Wires from that connector and other connectors go to a third connector which plugs into the 'upscale' radio.
If you had the 'pigtail' cable from the bezel and the odd connector that goes into the radio and access to the audio wiring schematic, the necessary wiring could be done. However, I would not recommend this project to a less than experienced person. In short - if you want better sound or more features, go aftermarket.
