Old 04-24-2008, 11:51 AM   #7 (permalink)
goathead
goathead's Avatar
Re: Cleaning up a paint rub/scratch.
Originally Posted by Skyboi
It would probably work but you have to be careful once you introduce a machine. The properties of grit change when you apply pressure and heat.
I would start with a glaze and a foam pad and work toward more aggressive grits. You can always take a little off but you can't put a little back.
Black is not very forgiving so be careful...
thats the part that im worried about. i will post some pre/post pics when i do it.
steve
