Old 04-25-2008, 05:27 PM   #3 (permalink)
loufish
loufish's Avatar
Re: Towing 28 ft TT with 2005 4x2 KC SE w/o BT
If you can't get LT tires by the next outiing, make sure the trucks tires are at their max cold pressure setting.
Also, load as much stuff as you can in the trailer, that will help get the trucks weight down. You do need to spend some time in a flat parking lot to get the WD set up correctly...That trailers a little over 28 ft...I wouldn't want to tow anything longer then that(guys here will tell you they do it, but I wouldn't...)
Correct tire pressure, WD set up correctly, added tongue weight( batteries, propane tanks and propane) should relieve most of that white knuckle...
Your trailer has a GVW of 7620, that's right at a non-tow Titan's limit, but if you don't load everything you own in it, you'll get by...
Add 300-400 lbs to the trailers empty weight to get a more realistic number.
PRG Performance Kit w/SAW's
Born 9/2004
2002 Honda XR650R
