Old 04-25-2008, 07:41 PM   #8 (permalink)
TallTexan
TallTexan's Avatar
Re: Towing 28 ft TT with 2005 4x2 KC SE w/o BT
My opinion. You should be fine without the air bags. The Reese hitch is a good one and should allow you to keep your truck level fairly easy. I would keep your tanks empty except maybe 25 gallons in your fresh water tank. You can fill up after you get where you are going. Set up your equalizer hitch properly and go camping. I have pulled for a long time and my trailer is 32 ft long and weighs approx 7800 lbs. I have a CC with big tow and it pulls nicely. I have pulled on freeways and backroads and no problems. I do not drive fast. 60 mph is fast enough. Normally 55. The Titan has no problem pulling. The weak link has been the rear end and weak springs in the rear. You can always install a set of Roadmasters if you need a little more weight carrying capability. Make sure your trailer tires are at the right pressure. Have fun.
Robert Louis Stevenson
