hello 1st post well i have a bit of a problem, i have a 2006 titan se 4x4 40k miles i replace my brake pads today fron and rear, ceramic pads didnot disconet any hoses from the calipers @ all and did not turn the rotors the look ok but know my brake pedal is really soft i have to press pas mid way for the truck to stop what you guys thik i should do i have a issue the wen i press the brake pedal my stering will vibrate but now with new pads that stop what should i do thank you
Yes you do...spelling and grammer...
Now for your truck, it sounds like the rotors were not OK...you may need to turn/replace them.
You pushed the caliper pistons back into the caliper to install the new pads, and sometimes this can cause issues. Many guys will crack open the bleeder screw while pressing the pistons back.
After bedding in the brake pads, do a couple of panic stops hard enough to go into the ABS mode. This will do an internal ABS bleed that often times will get the brake pedal where it belongs...
When "u" type, take a breath every now and then...
