Old 04-27-2008, 12:42 AM   #20
bgbdwlf2500
Re: pulling a stuck vehicle
Originally Posted by John Harden
Don't ever pull in reverse unless it is an emergency (life and limb type of thing). The problem is you're putting all the stress on your reverse gears in your transmission, and they're not designed for that kind of load.
The proper way is to use a tow shackle assembly in your hitch and tug, not yank them while you drive forward.
I've done this quite a few times and it usually works. Nowadays, I don't strap people out, I just use the winch.
Strapping is violent and jerky with tons of forces being applied all in an instant. Winching is slow, more easily controlled, methodical, and in my experience usually works much better.
Regards,
John
i agree except reverse is the lowest ratio which would be good for pulling..my dmax was that way, maybe the titan is not
07 GMC Sierra Onyx Black
Crew Cab 2wd
5.3L with 3.73's and G80 locking rear
Readylift Leveling kit
Herculiner DIY roll on bed liner
8000k HID lows
10000k HID highs
former daily driven 13.10@102 Duramax driver..not a guru by any means but if you have any Dmax questions pm me...
bgbdwlf2500 is offline   Reply With Quote
