Originally Posted by maxima619
Nice ultras.... I ordered the black ones..17x10 and -25 offset and 3 weeks of back order
I also was looking to get the Jesse James widows.. but they are $325 a piece! and the ultras are only $108 a Piece!
I think those are too wide and will cause problems.
2" wider thank stock -25 off set will put the inner wheel lip at the stock backspacing so you will have 2" sticking out. so when you turn the outside corner of the tire will most likely rub. NO! that wheel is a total of 11" wide divided 2 = 5.5" with 0 offset that wheel will have you sticking out 3" with a -25 offset.
4.5" backspacing.
I think you should change your order.
to this or this.
part# 175-7884B 17x8 offset:+25 lug pattern: 6on5.5 bore: 78mm hub centric
part# 175-7883B 17x8 offset:+10 lug pattern: 6on5.5 bore:108mm lug centric
