Old 04-27-2008, 10:17 PM   #25 (permalink)
maxima619
maxima619's Avatar
Send a message via MSN to maxima619
Re: Going With T-h-e-s-e
I think they got almost the same specs as my procomps.... but I'll see once they get to the shop... or even better I'll see what we have in stock with the same specs as the ultras an thest fit them.
Originally Posted by BECHLYF
I think those are too wide and will cause problems. 2" wider thank stock -25 off set will put the inner wheel lip at the stock backspacing so you will have 2" sticking out. so when you turn the outside corner of the tire will most likely rub. NO! that wheel is a total of 11" wide divided 2 = 5.5" with 0 offset that wheel will have you sticking out 3" with a -25 offset. 4.5" backspacing. I think you should change your order.
to this or this.
part# 175-7884B 17x8 offset:+25 lug pattern: 6on5.5 bore: 78mm hub centric
part# 175-7883B 17x8 offset:+10 lug pattern: 6on5.5 bore:108mm lug centric
2006 Nissan Titan CC LE A60: Suspension mods and bolt ons & frp fenders by ionic dynamics
1998 Nissan Cefiro A32:3XX WHP Highlt modded by Ionic Dynamics
1990 Nissan Fairlady Z32 twin turbo:J-SPECT 400WHP+ by Ionic Dynamics
2009 Nissan Skyline GTR R35: Waiting list White pearl premium package
Braket lifts are rock crawling suxx, desert rules
maxima619 is offline   Reply With Quote
