Re: Transfer case and diff'l fluid change
I'm going to go out on a very short limb here and say that there is no filter in the transfer case. I have not heard of having a filter in a transfer case before and I don't recall seeing anything close to a transfer case pan where a filter would be serviced from.
As I recall I used the RTV on the drain plug. No problems yet. I might go with teflon tape next time since it is a lot cleaner and easier to use..
Jim
