Old 04-28-2008, 09:26 PM   #8 (permalink)
NorCal 4x4
NorCal 4x4's Avatar
Re: Anyone Running These
Originally Posted by CODERED-TITAN
how about the toyos 285 75 17's on same rims??? skinner tire same diam. would they fit better?
Somewhat less likely to rub at the pinch weld, but backspacing, wheel width, and tire diameter are the biggest factors, except for really wide knobby M/Ts.
I also looked at those ... and they are a better fit for the stock 17s, (for anyone that wants to keep their stockers). The Toyo A/T 34s are heavier though. The Nittos are 61 lbs. and the Toyos are 67 lbs. so you might feel the difference in acceleration and about 1/2 mpg hit at the pump ... compared to the Nittos, (closer to 1.5 to 2 mpg compared to stock). On the positive side they have a 3-ply side-wall, but both are E-rated. If you don't have BT or OR gears, stick to a 33.
Btw, here's a pic of my Titan when it was 2" leveled, (with coilovers), and the aftermarket, 32.8" BFG AT KO LT285/70/17 58 lbs. tires. Looks well balance for a 2" lift, IMO, and only cost me 1 mpg over the stock 44 lbs. tires.
Another good choice for a level kit is the 33.2" LT295/70/17 Nitto TGs, that loufish is running. Better fit for a 2" level kit IMO.
NorCal 4x4 is online now   Reply With Quote
