Old 04-29-2008, 08:32 AM   #29 (permalink)
BECHLYF
BECHLYF's Avatar
Re: Going With T-h-e-s-e
Originally Posted by maxima619
just found the info on my procomps 1079-7938*17x9 6x5.5 -6mm 4.75" and no rubbing issues with just the spindles......... I guess I'm going to have to get a differente off set.......
The Pro-comp's you have now stick out 1-3/4" more than stock and the 10" wide -25 offset would have stuck out 1-1/4" more than that. Having the wheel specs that far off from stock is not good for the wheel bearing's either. after a while you will hear click click click click............time for new wheel bearing's.
