Re: SAW's on the way
Originally Posted by Schrute
Is this true? Can you run the bracket lift SAW's without a bracket lift? This is the first I've heard of this... Doesn't seem possible, but if true I wish I would have known about this sooner!!! Need to call Greg.
I was hoping the same thing but Greg said its not possible. They are just too long! That was my hold up, I wanted the SAW's but I also didnt want to spend the money because I knew I'd want a lift eventually too...
Chad
AKA "Mini Whore™" And now AudioWhore™
MODS: CST 7" lift, PRG UCA, SAW coilovers, SAW rear shocks, Deaver spring pack, PRG blocks, MotoMetal 951's 20x9, Mickey Thompson 35x13.5 Baja ATZ, S&B intake, Flowmaster Delta 50 muffler, Borla tip, 2* timing, projector lights, HID conversion (fog and low beam), Eclipse CD5000, 2x Arc Audio XXK-2500's, CDT speakers HD-M6 mid, braxial mount DRT-26 tweeter, Upstage 500XT, ES-01 tweeters CL-6x (rear fill), HD-10" sub, Tech12volts box, Kicker wiring, Ramatt sound deading, Active Tuning grounding kit. More to come!
