05-01-2008, 03:21 PM
#7
Re: Tire question
I'm pretty sure that the Tire Max Load Rating is a max weight placed on a single tire. If your max load rating is 3,970 then that means you have 7,940 truck rear + tongue weight that can be distributed evenly but you won't want to push it that close to the limit because of sway so I'd keep it closer to 3,000 truck rear + tongue weight. Keep in mind that your rear tires are only holding the trailer's tongue up, not the entire trailer.
Quite a few Armada owners tow with the Revos and love them. The Toyo Open Country and Nitto Terra Grappler should also do well and their max load ratings are close to the Revo's.
2005 Armada LE 4x4 - 2* Timing Advance - AirBox Mod - PRG Mini-Lift - Nitto TerraGrapplers 325/60-18
_____________
. Check out my Gallery! .
