Old 05-01-2008, 10:51 PM   #1 (permalink)
gksmith
TBS - huh, can you repeat that?
I noticed a company on Ebay selling TBS systems. They had 2 listings that seem to contradict each other.
Auction #1 - YOU ARE BIDDING ON A "HELIX" 1 INCH BILLET THROTTLE BODY SPACER: Throttle Body Spacer bolts in front of the throttle body to cause a turbulent spinning action of the incoming air as it passes through the throttle body. This causes the air/fuel mixture to atomize more completely, producing tremendous gains in mid-range power and overall efficiency. This effect will improve drivability of the vehicle as well as increase performance and quicken acceleration. Torque gains between 900 to 3500 RPM, increase towing capability. Gas mileage could increase 2-4 miles per gallon.
Auction #2 - YOU ARE BIDDING ON A "HELIX" 1 INCH BILLET THROTTLE BODY SPACER : Throttle Body Spacer bolts in front of the throttle body to cause a powerful smooth action of the incoming air as it passes through the throttle body. This causes the air/fuel mixture to atomize more completely, producing tremendous gains in mid-range power and overall efficiency. This effect will improve drivability of the vehicle as well as increase performance and quicken acceleration. Torque gains between 900 to 3500 RPM, increase towing capability. Gas mileage could increase 2-4 miles per gallon.
The second auction is cheaper - I guess you aren't paying for the helix.
The images shown for each auction are different - one has ridges the other is smooth. Not sure how the smooth would work as the stock throttle is also smooth.
2008 4X4 Se CC LWB "Timberline", Popular Package with Captain Chairs, Big Tow, 1Start remote starter, 2* Timing Advance, Westin Sure-Grip Side Steps, Active Tuning, Bed Extender, M&D Dvd & Monitor, Oem Hood Protector, OEM Bed Extender, Vent Visors, HotShot Wiper Fluid Heater, HID conversion, Line of Fire LED bar, OEM Nav Bezel, Garmin Street Pilot 7500, and Boyo VTL350 Backup Camera, Leer 100R Truck Cap, RoadMaster Active Suspension, and 2 Nissan Titan Hats
To be Installed: *Nothing*
gksmith is offline   Reply With Quote
