Old 05-02-2008, 09:07 AM   #5 (permalink)
firulice
Re: Fix for air pressure sensors??????
Originally Posted by fdlock890
Hello all.
I have replaced my stock rims and tires with 20" and toyo 33-12.5 20's. The problem is that the tirese need to inflated to 65-80 lbs, so my tire problem light comes on, and my tire pressure readings are just x's. Is their a fix for this problem? The dealer says the computer can not be recalibrated to the increased air pressure, and that the computer can only read up to 55 lbs. Does anyone know of a fix for this? Thanks Lock
Don't run them that high! It says that on the tire as max but you should run them from 30-35psi. Call around to a few shops that sell the toyo's and ask what they suggest running them at. I did that on my toyo mt's and they said 30-35. If you run them that high you will wear the inner part of your tire down too fast. I run mine at 35
