Old 05-02-2008, 09:42 AM   #7 (permalink)
Pops
Pops's Avatar
Re: Fix for air pressure sensors??????
Don't air them up that high. 32-35 PSI is plenty enough air pressure for these, it's frustrating to me when tire shops try to use the Max Pressure as if it's a Recommended Pressure. The Recommended Pressure is based on your vehicle and use, NOT the tires themselves. 60 PSI was causing problems for mine too, 35-psi is about perfect.
http://fitments.toyo.com/guide/
Originally Posted by Toyo
This bulletin supersedes all prior Toyo publications related to tire inflation for multipurpose passenger vehicles, including recreational vehicles. The purpose of this bulletin is to disseminate Toyo's recommendation and policy regarding inflation and tire maintenance of original equipment tires and direct replacement tires (same size and load range) on multipurpose passenger vehicles.
For the purpose of this bulletin, multipurpose passenger vehicles include all vehicles equipped with LT designated tires or medium duty truck tires. Multipurpose passenger vehicles include recreational vehicles (including class A, C, and B RVs), busses, and EMS (emergency medical service) vehicles.
Inflation of Original Equipment Tires on Multipurpose Passenger Vehicles:
Toyo's policy is to maintain the pressure specified on the vehicle's tire information placard (certification label) as established by the vehicle manufacturer or final stage manufacturer.
Replacement tires must also be capable of supporting no less than the vehicle's GAWR (per axle). Tire Inflation and GAWR Information:
The vehicle's tire information placard (certification label) includes information regarding the tire size, inflation, GAWR and other information. The tire information placard is usually located on the driver's door hinge pillar,door latch post, or the door edge. In RVs the tire information placard is placed on the bulkhead at the left of the driver's seating position.
Example – Tire Information Placard (Certification label):
2005 Armada LE 4x4 - 2* Timing Advance - AirBox Mod - PRG Mini-Lift - Nitto TerraGrapplers 325/60-18
_____________
. Check out my Gallery! .
Pops is online now   Reply With Quote
