Originally Posted by nissan72
I had mine flushed at the stealership at 30,000(on my 06' XE CC). I mainly did it because it was given to me by the stealership for free because they screwed up on another service. I sold the truck with 36,000 on it and got a 08.5 SE CC, but didn't have problems with the trans before selling it. Normally I'm not big on these type of things or I try to do them myself, but apparently the stealership actually has a machine to vacuum all the fluid out and replace it. Apparently you don't get all the old fluid out by just draining it yourself. I will probably do it on the 08.5 just so the stealership doesnt give me a hard time if I need warranty work done after the 36,000 mile warranty. After that I'll probably wait a long time till I do it again. You can do a search and see what other guys do about this and there's some threads that talk about what guys here have paid for the service as well. Good Luck
yeah drain and fills only swap the fluid out in the pan, to get the fluid out of the torque converter you gotta do a flush with a machine like a t-tech.
